03: ABS Brakes Fault Code
Old Sep 26, 2004 | 01:55 PM
dimitristx's Avatar
Default 03: ABS Brakes Fault Code
It's coming up every few days as "Intermittent". I clean it and comes back.
Any ideas? Here's the exact info:
03: ABS Brakes
Component: ABS/ESP allrad D56
Brake Pressure Sensor 1 (G201)
48-10 Supply Voltage -- Intermittent
Old Sep 26, 2004 | 06:10 PM
Sven_S8's Avatar
Junior Member
Default Could be brake light switch, wiring or sensor
Don't you have the fault code? (nr.)
I'd start with the brake light switch. Easiest, and that's happened more often.
There could be other issues, like the wiring, sensor or control unit. But methinks the ABS light would come on if it were more serious.
fliparto
VAG-COM Discussion
Nov 25, 2012 11:55 AM
CincyQuattro
Dec 17, 2007 06:24 PM
boostedTT
Apr 13, 2005 07:07 AM
specialidiot
Jan 18, 2005 07:15 AM
dimitristx
VAG-COM Discussion
Sep 26, 2004 01:54 PM
