ABS problem
Old May 29, 2004 | 11:23 AM
backdoc's Avatar
New Member
Default ABS problem
Was having the typical A8 ABS noise followed by the brake, and abs lights coming on for the past few months. Today decided to pull the left front ABS sensor to clean it. The sensor must have been fused in there, because I broke it right off. Now what do I do? Can't even get the rest of the sensor out. I remember reading in a past post that someone pulled the fuse for the ABS, and just drove around without it. Which fuse? There are three to choose from. Two in the right footwell, and one in the trunk. Just want to pull the fuse as a temporary fix until I figure out what I am going to do. Thanks!
Doug G.
Old May 29, 2004 | 01:48 PM
mission's Avatar
New Member
Default That Sucks. I Feel Your Pain.
Sorry... I don't have any answers for you. I just wanted to send my condolences.
Old May 29, 2004 | 02:02 PM
PaulW's Avatar
Default I'd have to look it up....
....I could do it for you tomorrow. I'm sure you could easily drill the sensor out. Shouldn't be that hard.
Old May 29, 2004 | 06:03 PM
backdoc's Avatar
New Member
Default Re: I'd have to look it up....
Thanks Paul. I can't remember who posted the thread about pulling the fuses, but if you can give me any suggestions I'd appreciate it. The owners manual lists two fuses in the front footwell in the blue fuse carrier. Fuse # 9 is the "ABS control unit, terminal 30", and fuse # 10 is "ABS control unit, terminal 15". In the luggage compartment, fuses 1B, and 3A are "Anti-lock braking system". The cheapest ABS sensor I can find is $170 at "the parts bin" is there somewhere less expensive. Thanks again.
DougG.
1997A8Q
Old May 30, 2004 | 08:58 AM
PaulW's Avatar
Default There are multiple power supplies
<i>Disclaimer: I do not take responsibility for anything recommended below. These fuses could also power other systems that I have not checked.</i>
ST4 (blue), fuse S9, 5A (I would start with this one)
ST4 (blue), fuse S10, 10A
ST3 (yellow), fuse S1, 15A (powers ABS light and a lot of other stuff too)
ST2 (red), fuse S9, 10A (powers brake light switch, don't undo this one)
Luggage boot right, S53, ABS hydraulic pump
S54, ABS valves
Probably don't need to undo either of these in the trunk, you just want to undo the control above....I might try ST4, S9.
Old May 30, 2004 | 05:37 PM
backdoc's Avatar
New Member
Thanks Paul!
gtreng1
May 4, 2006 08:16 PM
pasty
Dec 7, 2005 01:30 PM
Kirk
Canadian Discussion
17
May 19, 2005 05:49 AM
S4-Fireblade
Audi Original "S" Cars
Apr 17, 2005 08:38 AM
SnackPack
Jan 27, 2003 11:32 PM
