abs sensor
Old Oct 18, 2004 | 12:09 PM
marcodant's Avatar
Junior Member
Default abs sensor
OK I got my vag FINALLY!!!!!!!!!. calls that the left abs sensor is opn/short. that is the reason for my abs and brake light on. I replaced the back rotors this weekend. I am going to try to fix the abs sensor first. has anyone tried too?? I am going to cut out the wire close to both ends of the plug and sesnor and replace with a new wire. Hope this works. also thanks to paul pulling my codes a few weeks ago I still have that check eng light. I am going to go through and test all the things bently suggest. thanks guys..
Old Oct 18, 2004 | 01:56 PM
user 62970120212's Avatar
Banned
Default How do you know it's the wire and not the sensor or connector?
If there's no visible damage to a wire, isn't it probably okay?
Aren't connectors or sensors more likely to give trouble?
Do the contacts in the plug and sensor look shiny and clean?
Did you check the sensor resistance as per the Bentley? (And do any other tests recommended therein?)
What happens if you swap sensors side-to-side?
Rewiring that will be subject to road spray must be done to a very high standard, so you may want to rule out the other stuff if you haven't already.
Tom
Old Oct 18, 2004 | 02:10 PM
marcodant's Avatar
Junior Member
Default Re: How do you know it's the wire and not the sensor or connector?
well to comfirm when I move the wire I trip the light.. the sensor is fine. the wire has a open about 6 inch up from the sensor.. I am cutting it now and so far so good.
Old Oct 18, 2004 | 02:38 PM
Banned
Default Okay, that makes sense
Please let us know how you waterproof the repair and how it turns out.
Thanks,
Tom
Old Oct 18, 2004 | 04:56 PM
marcodant's Avatar
Junior Member
Default Re: Okay, that makes sense
ok all fixed. the insulation on the abs sensor is rather thick. but the wire on the inside have very thin insulation on them. they are also very thin.. maybe 22 gauge.. But I did the repair and everything works like it should and best of all my brake and abs light are now off... next mission is the check engine light. After that is fixed then the tranny flush and then on to fun things.. I have to say that vag is very helpful.
Old Oct 18, 2004 | 09:53 PM
Banned
Default Well done, thanks for the information
Yes, VAG-COM is really useful when so many things can turn on the light!
Tom
Old Oct 19, 2004 | 05:36 AM
PaulW's Avatar
Great job, the tool is invaluable!
Old Oct 28, 2004 | 03:03 PM
CLeonard's Avatar
New Member
Default This is how I fixed my front/pass sensor
Cut the wire about 4" up from the sensor, and 4" from the connector, then put in my own wire. Very simple and I haven't had a problem since.
Colby
 Michael S. Palmer
Mumawalde
Aug 16, 2010 05:48 PM
VorsprungTT
Dec 11, 2007 03:43 AM
saul222
Jun 12, 2007 07:30 AM
a4avant99
Oct 6, 2005 06:28 PM
onyekachi
May 25, 2005 01:53 PM
