brake light problems
Then when i turn on my parking light and or headlights it lights up all of my parking lights and all of my brake lights with out me applying my brakes. I had a couple friends think its the multi function switch in the stearing wheel but i am not 100 percent sure.
Also leave the replaced lamp out, while you test the lights again, to see if the new abnormal behavior is still present.
Did you buy a good quality bulb or a cheapo from Walmart? It can make a difference.
If everything else is OK, I'd check the bulb holder assembly for corrosion/shorting. I once had a VW Jetta that the lights would go crazy on because of a crossover in current in the bulb holder assembly.
When i messed around a little more i noticed that when all of the lights are off and i apply the brake it also lighs up my front parking lights as well.
i have one more question, when i apply the brakes when the headlights r off it lights up my parking lights in the front and back it really doesnt bother me it would just be nice for it to work correcly. I was gonna see if u still think its a socket or a jumping circuit?
It "may" be possible, but have never heard of a lamp control module (relay) failing this way...BUT it's the ONLY other thing that the brake lights and parking lights have in common.
And really don't think it's possible for the light switch to do this...totally separate from the brake light circuit.
