Can 255/50/19 fit nice w/o rubbing on my 97 A8?
Old Aug 2, 2004 | 12:37 PM
Dre97A8's Avatar
New Member
Default Can 255/50/19 fit nice w/o rubbing on my 97 A8?
<center><img src="http://www.hpracing.com/images/products/50-HP16-199-12L.jpg"></center><p>I bought 19' HP EVO's for my 97 A8. I wanted to put 255/50/19 tires on my rims, but the sales man said it would rub. Is that true people? Or he doesn't know what he's talking about? I heard of guys having tire sizes 235/45/19 or something similar. The salesman said only 245/35/19. What can I throw on to have a nice ride? I don't want any rubbing of any sort. Thanks<ul><li><a href="http://www.hpracing.com/parts_detail_disp.php?part_no=50-HP16-199-12L&amp;id=49&amp;">HP RACING</a></li></ul>
Old Aug 2, 2004 | 12:40 PM
KaMaKaZieP -ALUMIN8-'s Avatar
Well 255/50 will be a TALL tire... i have 255/55/16's and they are close
Old Aug 2, 2004 | 12:55 PM
PaulW's Avatar
Default Need more info
First of all, what is the offset of the wheel? That will effect things....
Secondly...you CANNOT PUT ON 255/50/19's on your car....what are those for....a truck????
The outside diameter (OD) of a stock A8/S8 wheel is roughly 26.7"....
The OD of the a 255/50/19 is 29.0"!!!! That's way too big and will rub!
You need to figure out what your offset is....and then look at this <a href="http://www.miata.net/garage/tirecalc.html" target="_blank">tire size calculator</a> and use 245/45/18 as the stock size.
Also, you need to look at <a href="http://www.audipages.com/upgrades/tiresizeoptions.html" target="_blank">audipages tire size options</a>. You are trying to match the OD of the stock tire with your new width on a 19" wheel.
It does show a 255/35-19 as 2% smaller OD than stock....it would look really silly on your car...so I don't know what your options are....you could do a 245/40-19 and get a perfect match to the stock OD.
I don't know if they make a 255 width with a 19" rim that matches the OD of the stock A8/S8.
Old Aug 2, 2004 | 01:05 PM
Dre97A8's Avatar
New Member
Default Re: Need more info
Well tirerack recommends 255/40/19. Thanks ppl.
Old Aug 2, 2004 | 01:12 PM
Dre97A8's Avatar
New Member
Default Well it looks like the biggest tire I can fit is 255/40/19
I just hope I don't hit a bad pot hole. It's great that I live in NYC... yeah right
Old Aug 2, 2004 | 01:14 PM
PaulW's Avatar
Default That would work
It would be 1% great OD than stock, 27.0"....that would work...
So what is the offset of the wheel? You have 9.5" rims, that's already going to add 0.75" on the inside and outside of the rim...if you have an offset of 48, which I doubt they are....if they are et35 or et32, you should be just fine.
Old Aug 2, 2004 | 01:15 PM
PaulW's Avatar
Default With those things, I bet you bend one by November
Don't want you too, but I'm just guessing you will.
Old Aug 2, 2004 | 01:26 PM
Dre97A8's Avatar
New Member
Default it's really 19x 8.5 (couldn't find the right link)
8.5... was thinking about 9.5 in rear, but said no.
Old Aug 2, 2004 | 01:28 PM
Dre97A8's Avatar
New Member
Default well I had these on 18x 9 on passat and bended 1 :(
It sucks to live in brooklyn NY w/ nice wheels. The city likes to eat them.
Old Aug 2, 2004 | 01:43 PM
David Dell's Avatar
New Member
Default How about 255/50/R17 (for my a8, I mean)
Kamakaziep, does your comment mean the 255/50R17 I asked about in the Wheels and Tires forum should fit my 97 A8 with 8.5" wheels?
