check engine light on, need some help with codes
Old Apr 25, 2007 | 12:43 PM
illphil4's Avatar
Default check engine light on, need some help with codes
My check engine light came on about 3 days ago, i had the engine codes pulled with an OBD-II tool. It returned that pistons 1-4 were miss firing. I had all of the spark plugs replaced and the codes reset. about 5 minutes later the light came back on and now the code from the engine is "P1340 manfacurer control. ignition system or misfire" i tried looking up this error but came up with nothing. anyone know what the cause of this error might be?
Old Apr 25, 2007 | 01:01 PM
Always Overcharged's Avatar
Default also look at your knock sensors
Though the code you give is not on my list all the codes around that are talking about knock sensors so probably a good place to start.
It may be a fault with the ECU in the knock control
Ill look harder tonight
Old Apr 25, 2007 | 01:18 PM
tozoM8's Avatar
Tech Guru
Default It could be dirty engine speed sensor.
<ul><li><a href="http://autorepair.about.com/cs/troubleshooting/l/bl_obd_13.htm">http://autorepair.about.com/cs/troubleshooting/l/bl_obd_13.htm</a</li></ul>
Old Apr 25, 2007 | 11:51 PM
Default Have a look at your camshaft position sensors-I clicked the search
button with the code p1340 and there is lots of info.
Please post the result for the knowledge tree :-)
Old Apr 26, 2007 | 11:45 AM
illphil4's Avatar
Default Re: Have a look at your camshaft position sensors-I clicked the search
Thank you guys for the quick replies. I looked in the searches for the code but everything i found was about TT's or BMWs. I had the dealer look up the code for me too, they returned: "crank shaft position sensor out of sequence". They said they had no idea what the cause of the error might be with out looking at the car. Anyone know anything about this? Could this have anything to do with the spark plugs being changed? Any help is welcome. thanks in advance.
Old Apr 26, 2007 | 01:41 PM
tozoM8's Avatar
Tech Guru
Default I would clean the engine speed sensor. It's on the transmission driver's side front of the axle.
<center><img src="http://pictureposter.audiworld.com/80919/5hp24a.jpg"></center><p>
victor army
Jul 2, 2006 03:24 PM
lskolnick(original)
Jan 20, 2003 11:58 AM
kstein_S4
Nov 6, 2002 03:43 PM
kstein_S4
Nov 6, 2002 01:26 PM
