Cold A/C from pass. side only!
Old Jul 13, 2012 | 06:27 AM
troverman's Avatar
Default Cold A/C from pass. side only!
Recently the driver's side of our 1999 A8 will only blow seemingly ambient-temperature air (as if its pulling air from the outside and just blowing it in), while the passenger side (and center dash vent) blow the usual ice cold a/c air when the temp is turned down. I know the A/C system is fine if cold air comes form the passenger side. I'm suspecting one of the servo / blend motors is stuck or dead.
Does anyone have any more info about this problem? Where are the servos located? How hard to access? Any easy fixes?
THanks
Old Jul 13, 2012 | 11:02 AM
aduggs's Avatar
What happens if you turn the recirc on? Shouldn't be pulling any air from outside if the recirc works.
May help you narrow down the problem without vag-com. Vag-com will tell you which flaps are not matching their target settings. If they are off by +/- 5(?) they will save a fault.
Old Jul 13, 2012 | 11:04 AM
troverman's Avatar
Recirculating makes no difference, I don't think. I'll check tonight after work.
Old Jul 13, 2012 | 02:15 PM
silverd2's Avatar
THanks
Just means you're low on refrigerant...always the 1st sign in a D2. The refrigerant enters the passengers side of the evaporator, so whats left in your system cools that side first.
Self service >>>
http://forums.quattroworld.com/a8/msgs/15213.phtml
READ THIS, too, before buying anything !!!! >>>
http://forums.quattroworld.com/a8/msgs/69707.phtml
Old Jul 14, 2012 | 11:31 PM
audinutt's Avatar
Self service >>>
^^^^^^^ He is correct, I've been through this before.
-Richard
Old Jul 16, 2012 | 03:51 AM
troverman's Avatar
Where can I buy an adapter to fit the A8's low-side valve? $15 can is cheaper than $100 evac / refill by shop. Last time it was in for a recharge, shop said there was a small leak at the compressor, but a charge would probably last for a while, which was about 1.5 months ago.
Silverd2, thanks for info. Really not wanting to tear into dash.
Old Jul 16, 2012 | 04:40 AM
silverd2's Avatar
I bought my recharge kit at WalMart and I bought the adpater on eBay:
http://www.ebay.com/itm/FJC-6016-R13...0ca3c7&vxp=mtr
Sometimes see em at WalMart (Autozone or Advance), too.
Gdb09
Q5/SQ5 MKII Discussion
23
May 19, 2025 01:27 PM
jmndz
Q5/SQ5 MKI (8R) Discussion
9
Apr 23, 2016 01:36 PM
Dennis Gautreau
Oct 7, 2015 10:47 AM
toadusmodus
Audi allroad
Jul 19, 2011 11:51 AM
ak_nevin
Feb 13, 2005 03:30 AM
