Error Codes
Old Jan 19, 2006 | 02:05 AM
AndyZ's Avatar
New Member
Default Error Codes
Hi All
Fulltime "lurker" / sometime poster...
My '98 with 121k mi is throwing a consistent CEL and 4 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
If I reset the CEL, it comes back in about 50mi... Also, she occasionally idles rough when hot, put in a double dose of Techron to clean injectors, also accompanied by rough idle..... Any Suggestions? I am thinking it's an O2 sensor...
BTW I have an "uncured" hunting issue that I live with; & I'm about to do front a suspension rebuild and tranny output seal.
Mods: ECS two piece brakes, tranny coding, 17mm spacers, XM radio.
Thanks for your input, guys!
Old Jan 19, 2006 | 08:15 AM
Always Overcharged's Avatar
Default log o2 -should be -12 to +12 with warm engine
suggest it could be but seems funny that both banks gom at once= will show up there as code only sets when outside parameters
check for air intake leaks and clean filter etc
DO NOT use silicone near this area as it will kill sensors
schaeffer
Apr 9, 2012 09:45 AM
Biggeek
Oct 28, 2007 07:17 PM
LEH82
SoCal Discussion
Jun 14, 2007 05:46 AM
AndyZ
Florida Discussion
Jan 19, 2006 03:23 AM
AxeYrCat
20
Jun 28, 2004 10:41 AM
