few codes on my a8
And the codes for the AC i always get,What should i do? I can hear it blow, but for some reason it would blow strong cold air for 30 seconds and the next minute i can still hear the fan blowing but can't feel it, and its warm. I'm guessing the flaps close..
And also the ABS codes are new. any ideas?
Saturday,20,August,2011,20:57:02:36210
VCDS Version: Release 10.6.3
Address 01: Engine Labels: None
Control Module Part Number: 4D0 907 560 AL
Component and/or Version: 4.2L V8/5V G 0001
Software Coding: 06753
1 Fault Found:
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Control Module Part Number: 4D0 820 043 Q
Component and/or Version: A8-Klimavollautomat D12
Software Coding: 00180
3 Faults Found:
00711 - Left Footwell Flap Positioning Motor (V108)
41-10 - Blocked or No Voltage - Intermittent
00715 - Rear Footwell Vent Positioning Motor (V112)
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Control Module Part Number: 4D0 907 389 E
Component and/or Version: ABS/ESP allrad D26
Software Coding: 08397
2 Faults Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
00597 - Wheel Speed Impulses; Deviation
Large leak: hose split or loose somewhere in the EVAP system or possibly a seal on the gas tank where pump assembly or level sensor are attached..detected by the leak detection pump, which runs a diagnostic every time you start the car...and periodic checks after that.
The AC codes are leading you directly to the cause....see manual for location and disassembly/testing instructions.
The ABS code is a wheel speed sensor problem...Unless you have different size tires at the same time, ABS wheel sensor(s) (or the CV joint slotted rotor it reads) are dirty, faulty, installed incorrectly or wiring to them interrupted/shorted.
To do your own work requires the proper tools...if you don't have a manual, you do not have the proper tools.
i don't know which motor this is for the ac, i changed the other two and they work good now all i need is this one..
can you guys help me out locating it?
much thanks
much thanks
Here is the part number for the air recirculation motor : 4D0 820 511
By the way, the motor can be removed without it being a huge pain. All you really need is a very long shaft #2 phillips screwdriver. Remove 2 short screws that attach the cover OVER the motor, and then two long screws that actually hold the motor. Once you remove and replace the motor, you will need to reset/calibrate/adapt it using a VAGCOM.
Hope this fixes it for you. By the way, I highly recommend you verify that your air recirculation door hinges are free to move.
last week i bought 4 motors for the ac flaps, plus a bunch of little stuff i had missing like the cigaret lighter and stuff, all for 35 bucks, and he had no idea what it was for. So i am guessing i can get an even better deal than the one on ebay, but thanks for the advice.
thank you
