It happend again!
Old Dec 3, 2004 | 12:26 PM
Rixter 123's Avatar
New Member
Default It happend again!
Took the car out for a short drive, turned it off and couldn't get it restarted. I thought maybe there was a vacuum problem so I opened the gas cap and let it sit for a while, the car fired right up but wouldn't stay running....Any clues? (It's not the first time this has happened...)
Old Dec 3, 2004 | 12:31 PM
PaulW's Avatar
Would it turn over or just nothing?
Old Dec 3, 2004 | 04:18 PM
GDJT Allroad^2's Avatar
Stab in the dark would be fuel pump or filter or relay, but that's without a VAG to go on.
Old Dec 3, 2004 | 05:54 PM
backdoc's Avatar
New Member
Default main battery ground
last winter, my wife took the A8 to her hairdressers. When she was done, she couldn't start the car. All the electronics worked, but the car wouldn't even turn over. It turned out to be the main battery and starter ground. It was all corroded from the salt on the road in the winter. Had it flat-bedded to my local mechanic, and he cleaned it up and fixed it. One other time, my car wouldn't start, but it would turn over. That problem turned out to be a bad ECU. Good luck.
Doug G.
97 A8Q 111K
Old Dec 3, 2004 | 06:16 PM
tozoM8's Avatar
Tech Guru
Default There is a power connection attached to the frame near the starter, on the bottom right side....
of the car. It has a plastic cover, but mine was very rusted.
Old Dec 4, 2004 | 04:20 AM
Rixter 123's Avatar
New Member
Default Re: Would it turn over or just nothing?
It cranked perfectly, it just wouldn't fire up. This happened once before, but after letting the car sit for two or three days it was fine.
My assured warranty ran out two months ago.... I knoew this would happen!
Old Dec 4, 2004 | 06:51 AM
A8CT's Avatar
I had a similar problem when I bought my car and it was the fuel pump relay
Old Dec 4, 2004 | 02:45 PM
LenVOS8's Avatar
Default Re: My S8 is at the dealer with the same symptoms now....
The diagnosis was that the electronics in the instrument cluster went and they are linked to the engine control computer. Of course I am waiting now (it will me two weeks come Monday)for the parts to come from Germany; hopefully the tech at the dealer made the right guess - S8 down to A4 1.8t is a pretty big difference to get used to.
Does your instrument cluster come on when you turn the ignition on? Mine didn't no odometer or other indicators lit.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 4, 2004 | 02:59 PM
Rixter 123's Avatar
New Member
Default Th e instrument cluster lit up
but what I noticed was that the "PRND" symbols were lit up in one continuous bar.
I hope it's something simple.
btw- Can a VAG be run on the car without it running?
Old Dec 4, 2004 | 03:12 PM
tozoM8's Avatar
Tech Guru
Default You need to VAG-COM it.
You can VAG-COM it, you just need the ignition on. The continuous bar means, transmission is in limp home mode, but in this case it is hard to guess.
joloya
Dec 26, 2009 08:24 AM
Bruno_S4
Aug 9, 2006 09:02 AM
Monster-S4
16
Jul 23, 2005 02:55 PM
Meigwen
Audi 100 / A6 (C4 Platform)
Dec 7, 2004 04:34 PM
KLALE
Sep 25, 2001 09:50 AM
