Help needed
Any advice here is very appreciated, thank you!
, It was a quite a mystery, because I changed the control arms about 1000miles ago, and the ones which control the steering were damaged, and one loosen bolt. The 4th mechanic discovered that,he couldnt align the wheels it was new and already damaged, that was the scary noise and braking by itself, next time I check better also the new parts...
The other thought is that the arms or axle are the wrong length and it is straining beyond it's range when you make a turn, but the problem started before you started changing parts, right?
