Indicator Problem
Any ideas
I suspect that it is either a faulty hazard switch or column switch (arm) but without a wiring diagram I don't know if the turn indicator wiring passes through the hazard switch. If it is the hazard switch can anyone help is dismantling the centre console to get at the switch???
My car is UK spec and has only two airbags in the front, one on the wheel and one above the glovebox. Are you refering to either of these or is there an airbag impact trigger located centrally in the dash. (or does a US spec car have more airbags??)
Went to a UK Audi garage today who said that 99% of indicator problems were with the hazard switch.
I like the answer GMikes97A8Q gave; it a go.
[re-ignitiom switch, unlikely, mine was replaced recently and everything else works ok- thanks anyway]
David
