Led conversion — warning light problem
Old Feb 28, 2019 | 05:39 AM
steve burke's Avatar
Default Led conversion — warning light problem
Just installed led lamps in the rear running lights and brake lights. Unfortunately the dashboard warning light now comes on. Any idea how to remedy this?
thanks a ton! Steve
Old Feb 28, 2019 | 09:56 AM
jfrahm's Avatar
Usually you buy CANBUS compatible LEDs. What car do you have?
Old Feb 28, 2019 | 10:16 AM
Hi JFRAM, the car is a 2000 A8
Old Feb 28, 2019 | 12:17 PM
SC_09iduA's Avatar
Lots of Rings
I would first try (if you cannot return newly installed bulbs) load resistors...they will enable the computer to recognize the bulbs..though you will not retain the power savings, you will have functioning bulbs and "no codes." I would suggest the 50w versions available...
Amazon Amazon
Old Mar 2, 2019 | 10:39 AM
BrianC72gt's Avatar
The load resistors consume current and convert it into heat. Be mindful where you place them.
Blaster an
Q5/SQ5 MKI (8R) Discussion
Nov 8, 2013 05:18 PM
Audis or VWs 4Life
Oct 13, 2005 07:22 PM
quattro90S6
New England Discussion
Feb 3, 2004 08:43 AM
