LPG conversion completed..
Old Feb 25, 2012 | 09:53 PM
dallas0029's Avatar
Default LPG conversion completed..
Well, apart from detail things that i want to fix and shape a new cold air intake pipe.
The installer that did the job where unable to connect to the ECU. I got the kit from the UK as they are less than half the price compared to Australian sourced kits. A few emails and i had my own lap top all connected. So tuned it myself so far. Still running a little lean despite adding opening time to the gas injector opening times, so may have to drill out the nozzle holes. Injectors, as all LPG gas ones are, are noisier. Still smooth as the Audi V8 should be a few seconds after change over. No MPG figures yet, thats a week or so away.
Tank is 65 litres. The LPG ECU is located in the bottom of the air box. The tuning part is actually the fun part! No change to spark plugs, still using the standard Bosch plugs. Added an electronic "Flaslube" brand valve saver kit for the fact LPG is a drier fuel. I have to do the timing chain, water pump, thermostat and oil cooler job later this year, so most of the gear doesn't have to be moved.
Any questions or suggestions, shoot!
Old Feb 26, 2012 | 07:44 AM
Perpetual Novice's Avatar
Nice! what was the brand of the kit?
Can we see it without the engine covers?
Out of curiosity, whats the cost of LPG in Oz?
Old Feb 26, 2012 | 08:10 AM
dallas0029's Avatar
It was a kit i got from the UK by AG centrum. Supplier very helpful. Usually LPG in Oz is around 60-65 cents per litre. Due to the cold northern winter this year our prices have blown out to 72-77 cents per litre.
Next time i have to take the covers off ill add the pic!
Old Mar 4, 2012 | 02:54 PM
dallas0029's Avatar
Update on fuel use. Now i have finalised the LPG fuel map i am using around 13.7 l/100kms of LPG for my return trip to work. Which is urban driving with some stretches of 80k/hr road.
Old Mar 5, 2012 | 04:54 AM
Originally Posted by dallas0029
I am using around 13.7 l/100kms of LPG for my return trip to work. Which is urban driving with some stretches of 80k/hr road.
Thank you for the data point!
In Imperial units that's 12.5 miles per gallon of LPG. LPG is typically quoted as 1.35 gallons LPG/gallon of Gas equivalent, so 12.5 MPG relates to about 16.9 MPG (gasoline).
My dash typically says I'm getting 19 MPG avg, but the odometer and fuel pump tell me its closer to 17. Here in Houston the price of LPG is about $3/gal...so assuming I get the same mileage you do, my fuel cost with LPG would actually go UP slightly compared to my fuel cost on regular old gasoline.
I guess I'll keep my motor nice and stock for now, but as Gas goes up and LPG stays stable, it might be good for my next A8.
maarp
Nov 16, 2010 03:26 PM
yota-toy
Apr 12, 2009 05:45 PM
Whitjr
15
Feb 8, 2006 12:04 AM
TerminA8r
Misc. Models Discussion
13
May 20, 2001 03:21 PM
njkadesi
Mar 1, 2001 09:54 AM
