memory switch - backlight fix
Old Mar 25, 2007 | 02:12 PM
A8CT's Avatar
Default memory switch - backlight fix
<center><img src="http://pictureposter.audiworld.com/55607/misc_004.jpg"></center><p>
Not the most pressing issue, but everytime I got in my wife's car in the dark, I couldn't see the seat memory buttons because the backlighting was out.
I took it apart and there are 2 LEDS and a small 12v bulb. If the red on/off switch is lit up but you can't see any of the other buttons, the bulb is burned out. The "On/off" switch is illuminated by the LEDS and don't seem to be a problem.
The whole assembly comes out by unscrewing a phillips screw inside the door pocket and then you can lift the whole thing out and fix it on the bench.
The switch itself prys apart by pushing in a couple of tabs. It's a little tricky but you'll get it. Desolder the old bulb and use the Radioshack bulb as a replacement. You'll need to cut about 1/2 of each leg so it doesn't sit too high. You'll also need to make the hole in the rubber piece slightly larger so the bulb will fit.
The switch illuminates with the ignition key in the forward position, there's no tie to the headlight/dash lights being on/off.
Bob
Old Mar 25, 2007 | 02:27 PM
Always Overcharged's Avatar
Default Excellent -I love the way forum members have the time to do the important
little jobs and even write them up so well.
I had an ashtray light in the rear that really bothered me as my son kept reminding me about it.
[no body smokes so it will never be needed but HEY thats no reason not to fix it
Old Mar 25, 2007 | 02:34 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Nice. What's the R/S part number? 272-1154?
Old Mar 25, 2007 | 02:57 PM
A8CT's Avatar
Yes, correct.
Old Mar 26, 2007 | 10:52 PM
Nickg-uk's Avatar
New Member
Default Re: Excellent -I love the way forum members have the time to do the important
omg (
i have just noticed mine dont work grrrrr, never look down there tbh always looking straight ahead !!
Going to fix it this afternoon because i hate bulbs that dont work!!
PS, you guys got a replacement form a shop, can i ask what the wattage of that bulb you fitted is ?.....12v 1.2w by any chance ??
bye for now
Old Mar 27, 2007 | 04:19 AM
A8CT's Avatar
Nick, not sure if you have Radio Shack's across the pond, that's where I got mine - 12v bulb
12vA90
Audi Original "S" Cars
10
Jun 13, 2008 08:36 PM
DaveInSaltLake
Audi 100 / A6 (C4 Platform)
May 28, 2007 01:44 PM
neis
Feb 11, 2003 01:38 PM
Ben
Sep 26, 1999 03:31 PM
TobyK
Misc. Models Discussion
Feb 3, 1999 02:02 PM
