Odd Electrical Problems...
Old Oct 1, 2004 | 11:30 AM
banal's Avatar
Default Odd Electrical Problems...
Since I bought my 01 A8L a few months ago I have had the following odd electrical problems.
- A few weeks after I got the car the rear sunshade button wouldn't work once. I shut off the car and turned it back on and it worked. A month later it wouldn't work again and even after restarting the car it wouldn't work. I went to work and a few hours later the rear sunshade button worked.
- Yesterday my passenger vanity light was very dim. Today it's fine.
- Yesterday my window lock button light was flickering. Today it's fine.
Strange... Should I worry?
Old Oct 1, 2004 | 11:54 AM
skiracer's Avatar
Sounds like possible ground problem- check for TSBs on this........
Old Oct 1, 2004 | 05:12 PM
tozoM8's Avatar
Tech Guru
Default Re: Odd Electrical Problems...
Mine does the same. The sunshade doesn't work if the car is on the sun too long. It always opens and closes in the early morning.
Old Oct 2, 2004 | 06:10 AM
dimitristx's Avatar
Yes, you should worry. Try an exorcism..
Old Oct 2, 2004 | 07:26 AM
user 62970120212's Avatar
Banned
Default What worked normally at the same time that other lights were dim or flickering?
For example, did you see whether the driver's vanity mirror light worked normally when the passenger's was dim? Were the other power window switches on the driver's door lighted normally when the window lock switch flickered?
And did those two problems only ever happen together?
Thanks,
Tom
Old Oct 2, 2004 | 09:30 AM
banal's Avatar
Default Re: others were fine
yeah that was the first thing i checked when i saw the passenger's side was dim... the driver's side was fine. none of the other lights were dim. these two were a day apart but not at the same time.
Old Oct 3, 2004 | 09:31 AM
Banned
Default Yes, look at the TSB...
The sunshade and passenger, but not driver, vanity mirror light share a wire between the B104 in-harness ground connection to the 43 chassis ground connection referenced in a 1998 TSB (URL below). Thanks to skiracer for remembering the TSB and PaulW for scanning it. Though the TSB is for 1997-1999 model years, it shows where ground point 43 is, and how to inspect and reassemble the connections. You should disconnect the battery before doing the service.
Some rear exterior lights use this ground wire, so if it has a bad connection, you may have more problems when using headlights or brakelights. Using the rear seat adjusters, rear seat heaters, or the right rear power window would also put current through the B104-to-43 ground wire.
Many more strange things could happen if other wires connected at ground point 43 develop bad connections.
I can't see anything other than the light itself or local wiring which would make the window lock button flicker while the other windows buttons remain normal.
Tom<ul><li><a href="https://forums.audiworld.com/a8/msgs/46914.phtml">https://forums.audiworld.com/a8/msgs/46914.phtml</a</li></ul>
Warhead
Q5/SQ5 MKI (8R) Discussion
9
Mar 6, 2023 04:58 PM
prof7
Sep 30, 2006 05:41 PM
MyaLover
Jan 19, 2005 07:22 AM
EBred86CGT
May 2, 2003 03:18 AM
