Trans coding problems
Old Feb 18, 2006 | 08:43 AM
Angus Beef's Avatar
Default Trans coding problems
Trying to recode back to 00002 from 00011. After hitting the "Do it!" button, I still have the same (old) code. Following Pauls instrustions to the T.
What am I missing?<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/codingtransmission.html">http://www.audipages.com/Tech_Articles/auto_transmission/codingtransmission.html</a</li></ul>
Old Feb 18, 2006 | 09:06 AM
kphani's Avatar
Default it may be a good thing that it won't allow you!!!!!
A few of us here experienced premature tranny damage shorty after recoding. Please research and be sure prior to proceeding. Thank you.
Old Feb 18, 2006 | 09:33 AM
marcodant's Avatar
Junior Member
first did you figure out what is your tranny issue?
Old Feb 18, 2006 | 10:04 AM
kphani's Avatar
sorry, i misread your posting, thought you were going to 00011.
Old Feb 18, 2006 | 10:21 AM
Angus Beef's Avatar
Default YES! In fact I just finished cleaning my hands.
This thing had all the symptoms of burned clutch packs, but this is what I found:
The G195 sensor had a drity plug, once that was clean I checked the trans fluid.
Observations: the Trans needs to be 30 degrees C when checking. Yesterday it was 71F here, and I could not get it cool enough (It was still 58C after sitting overnight. We had a cold snap last night and snow. VAG told me this AM that the trans temp was 32C. I checked the level, and it took .75 liters. Out of the total 10.2 liters (IIRC) that is a very small % level low.
Further oberservations- In the South, except for in the dead of winter, there is NO WAY that you could get the tranny cold enough to properly refill the trans!! This (I'm speculating) might be why so many ppl have had failures after fluid changes. That fluid expands TREMENDOUSLY with heat! (Conversely, its contractions in cold were enough to suck the sides of the bottle in over night.) Unless you have a very cold ambient temp, you just arent going to get enough fluid back in the trans.
Thankfully I'm back to the "No Hunt, No Thump" at 154,000 miles. Been coded to 00011 since 93,000.
Cheers to all of you for your help!
Old Feb 18, 2006 | 10:54 AM
Cybertron's Avatar
New Member
So what gear should the trans be in to get a proper level reading?
Old Feb 18, 2006 | 10:57 AM
Angus Beef's Avatar
The Bentley says Park, and that's what I used. But you have to be quick- the trans warms up fast!
Old Feb 18, 2006 | 11:09 AM
Cybertron's Avatar
New Member
So in park with the engine running, it should just trickle out ot the filler plug right?
 Michael S. Palmer
Old Feb 18, 2006 | 11:39 AM
marcodant's Avatar
Junior Member
great work
Old Feb 18, 2006 | 12:24 PM
Angus Beef's Avatar
Default yes, with the transmission fluid between 30-40C. If you can get the trans to 30C you have about
5 mins to work before you have to shut it down and let it cool again. Best to keep the VAG-COM connected and monitor temp while you work.
