Trans problem...again!
In trying to figure this out, I did a little experiment: rolling slowly downhill, I shut the engine off and restarted in neutral. As soon as the engine restarted, I quickly moved the shift lever into manual mode and selected 3rd gear. The car accepted this and seemed to drive normally. I could shift up or down. However, in downshifting to first, at slow speed, the trans quickly slammed back into limp mode (I think 4th gear).
I have a hard time thinking this is a mechanical issue. I can sit in Park with the engine off, ignition on, and move the trans into drive. After a second, it goes into limp mode...with the trans off. Could it be the XYZ switch? A bad solenoid? Reman trans is out of warranty now.
