Transmision coding?
Mine transmission has broke down, so I changed transmission and transmision controller (ECU I think). Before change on dashboard I had gears "PRNDS", now I have "PRND432", Sport mode is missing and gear changin on steer doesn't work.
My question is, do I have to reprogram the controller to get back working as normal? Or I have to put my old controller? Is it interchangeable?
Someone who knows more than me can probably answer your question easily if you can post the info from the green data plate on the transmission (just forward of the left axle) and the numbers on your TCU (TCM).
The data plate will look like this:
The Transmission control module is located here, and has model and programming details printed on it:
Some research shows that FUM and FBE are both 01L1 variants and are mechanically identical so I suspect the sole difference between the two codes is the TCU software, updated in July 2001 to have Sport mode (PRNDS). Normally you can't swap TCUs because they are hard-coded for the transmission ratios, but with the two having identical ratios I would try re-fitting the FUM TCU and see how it behaves. There is a good chance it will work just fine and give you PRNDS back.
If it doesn't though, then you will have to live with it as there are no coding options to change that stuff. Its all ECU firmware.
Try the old TCU and let us know what happens...
