trunk doesn't lock
Old Jun 23, 2005 | 11:58 AM
-OvO-'s Avatar
Default trunk doesn't lock
When I use the remote, or when I lock-all with the key in the drivers door. Remote release opens the lid, but it looks like release is vacuum-operated, but lock/unlock is electrical?
(btw, the key has not worked since I bought the car, it won't even go in. I thought maybe the PO had replaced the cylinder or whole trunk lid.)
Anybody familiar with this problem?
Old Jun 23, 2005 | 12:25 PM
tozoM8's Avatar
Tech Guru
You have a service key. It opens the doors and the ignition only.
Old Jun 23, 2005 | 01:30 PM
Dr.  Jitter's Avatar
New Member
Default Check this
1. Check the vacuum tube on the left of trunk cover (it's often disconnecting)
2. Check the position of keyhole (on the trunk). It must be vertically for operating from motor and horizontally for manual on/off
Old Jun 23, 2005 | 05:24 PM
-OvO-'s Avatar
Default Nope. My key unlocks the glove compartment.
Either the lock cylinder is damaged or keyed differently.
What I can't figure out is, when I use the remote to lock the car, shouldn't the trunk lock as well? It doesn't. The vacuum actuates the trunk release mechanism just fine, and I can see that working.
I guess I don't understand, mechanically, how the car locks the rear lid via remote control.
Old Jun 23, 2005 | 05:39 PM
tozoM8's Avatar
Tech Guru
Default It locks/unlocks it with air, but pop it open with power.
If the key doesn't go in the lock is damaged. Even if you have a wrong key it should go in, but you are not able to turn it.
Old Jun 23, 2005 | 05:53 PM
-OvO-'s Avatar
Default I don't mind if the key doesn't work
as long as I can make the remote work.
baz-cabrio
9
Feb 9, 2013 10:13 AM
JPRobertsons
Mar 27, 2009 07:42 AM
crossroads
Nov 10, 2008 05:14 PM
Remote
Jun 3, 2004 05:54 PM
muvment
May 10, 2003 04:17 AM
