!!!WHAT'S THE MOTION SENSOR CODE!!!
This is on a 99 A8 4.2 Q with Symphony radio
The adaptation function makes it possible to implement and store the following modification:
Setting of ultrasonic sensors can be adjusted such that they react less sensitively.
- Starting interior monitoring system On Board Diagnostic (OBD) page 01-137 .
Rapid data transfer HELP
Select function XX
Indicated on display:
- Enter "10" to select the function "Adaptation" and confirm entry with Q key.
Adaptation Q
Feed in channel number XX
- Enter "01" to select "adaptation channel 01" and confirm entry with Q key.
Channel 1 Adaptation 100
Sensitivity in % <- 1 3->
Indicated on display: The sensor sensitivity level is displayed: e. g. 100 %
Note:
The maximum ultrasonic sensor setting made at the factory is 100% and can be reduced to 50 %.
