07 s8 problems
VAG indicated a high pressure level was exceeded on the LP fuel line. I suspect some dirt or moisture in the fuel. On clearing out the codes the warning is gone. However the car never behaved abnormally and the fault has not returned.
TSB is 01 07 18 2013535/7 [an unusually long TSB number] dated 8/29/07. VIN range for the S8 is 004243 - 014023 and for the 4.2 is 000292 - 014126. W12's don't use FSI so wouldn't logically be affected.
If you haven't been in for a software update and you are in the VIN range, you might want to get that done.
Separately by the way, there is a TSB for 3.2 FSI's that does talk about stalling problems, but it doesn't include the V8's.
