2006 S8 Engine Remanufacture
As it seems the S8 engine is rare and hard to come by in the UK, has anyone ever had the engine re-manufactured? I have a misfiring (on 8 cylinders) 5.2L V10 S8, and I need an idea of how much more expensive it is to have the engine re-manufactured, than buy a reconditioned one. I just need a ballpark figure to work with.
Thanks
Marking as solved
Audi say the engine needs removal to investigate what caused a valve in cylinder 1 to be stuck open. There is no compression at all on cylinder 1, and a rocker arm was found out of place, so sounds fairly serious. I'm not sure of the state of the rest of the cylinders apart from 7/8 misfiring.
Like anyone, I would love to keep costs down, but also looking for reliability going forward.
Audi say the car seems solid for its age. I do have dodgy mileage on the odometer but nothing in the paperwork that suggests any engine issues. As it uses a timing chain, I wasn't expecting to have anything to do on the engine, because it was a smooth drive up until the problem.
Tell us what happened, did you over rev the engine, what lead up to this point, have you inspected and seen with your own eyes the rocker arm out of place, did you yourself do a compression test ?
Audi found the rocker arm not in place, and took photos. They also used a bore camera (I think) to take a photo of the valve stuck in the open position.
They took photos of the spark plugs which I bought the week before, and all but two were blackn. Only two plugs looked like new.
See number 12.
See number 12.
Last edited by Giovanni Giovino 6.0+6.0TT; Mar 25, 2018 at 04:19 PM. Reason: Layout
