AC not cold
turning the temp up all the way to HI blew even hotter than outside air. Back to LO turned off the sauna and not so cold air. This tells me the temp control working
Econ off and on works as the fast fan goes and compressor goes off when on.
So how do I get the frosty cold felt at the pipe inside the car? Any thoughts?
Cheers,
Louis
Most garages have the machine to evacuate and fill with proper amount. But the pressure gauge can tell you if there is another reason for not cooling.
I can’t think of any instance like this over the years on the board where there wasn’t a part failure that the fix wasn’t ultimately a proper evacuation and recharge with the correct weight (600g) of refrigerant.
