Sponsored by:
Sponsored by:
CHECK ENGINE LIGHT - FAULTS INCLUDED
Old 11-17-2018, 08:25 AM
Basenco's Avatar
Default CHECK ENGINE LIGHT - FAULTS INCLUDED
Greetings all,
Just yesterday morning received the check engine light and I ran VCDS today and it shows the following faults:
Please let me know what I need to address. Thank you.
Saturday,17, November,2018,08:37:02:61955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
Ross-Tech: Home
Dealer/Shop Name: Barry
VIN: WAURVAFAXAN005884 License Plate:
Chassis Type: FA (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 28 34 36 37
38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 72 76 77
VIN: WAURVAFAXAN005884 Mileage: 144790km-89968miles
01-Engine -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (BVJ) Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 P HW: 4E1 907 560
Component: 4.2l V8/4V 0030
Revision: 71H28--- Serial number: AUX3Z0J0771648
Coding: 01060009190F0220
Shop #: WSC 02313 785 00200
VCID: 2F3BEED7EB126C4F37F-807A
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 144624 km
Time Indication: 0
Date: 2018.11.11
Time: 17:13:35
Freeze Frame:
RPM: 3004 /min
Load: 93.7 %
Speed: 80.0 km/h
Temperature: 90.0°C
Temperature: 18.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 144624 km
Time Indication: 0
Date: 2018.11.11
Time: 17:13:35
Freeze Frame:
RPM: 3004 /min
Load: 93.7 %
Speed: 80.0 km/h
Temperature: 90.0°C
Temperature: 18.0°C
Voltage: 13.462 V
004874 - Cylinder Disabling
P130A - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 144718 km
Time Indication: 0
Date: 2018.11.16
Time: 06:57:32
Freeze Frame:
RPM: 768 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 6.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000007767
Shop #: WSC 01104 444 53357
VCID: 20191DEBA6CCC337BE5-8074
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2536475998
Coding: 344530393135313035412056413032353336343735393938
Shop #: WSC 45453 001 1048576
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:44:20
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 135582 km
Time Indication: 0
Date: 2017.10.09
Time: 10:50:46
Old 11-17-2018, 09:24 AM
PaulW's Avatar
When was the last time you changed your spark plugs? If you haven't, that's where I would start. If you want to swap the cylinder number 8 coil pack with another cylinder while you are in there, if it comes back, and it goes to that cylinder that you changed the coil pack to, you know it's the coil pack. Basically the same thing happened to my 2010 Q5, it was a plug, but I replaced the plugs and the coil packs. Same basic codes.
Old 11-17-2018, 11:25 AM
Basenco's Avatar
Thanks much! I've had the car since January and I'll definitely start examining those coil packs and plugs for replacement.
Old 11-17-2018, 02:29 PM
PaulW's Avatar
If you are getting these codes and its shutting down a cylinder, I would not drive it unless absolutely necessary, you don't want unburnt fuel going into the CATs. But that's why it shuts the cylinder down.
Old 11-17-2018, 04:51 PM
Basenco's Avatar
I have another vehicle to drive until I get the parts and get on it. Thanks.
Old 11-18-2018, 12:08 PM
Basenco's Avatar
Thanks for your input. I did change out the plug and coil pack for cylinder 8 and it solved the misfire problem. I have to replace the other (7) plugs and packs but I will get them from the local dealership. Thanks again!
Old 11-18-2018, 01:31 PM
PaulW's Avatar
Awesome, glad to hear! I didn't do the plug change on my wife's Q5, had about 75K miles and look what happened. One just corroded and had the bad connection.....would be a lot easier to change them every 60K miles. I then went and bought new plugs for the S8 and changed them out before anything went wrong.
Old 11-20-2018, 04:19 AM
Basenco's Avatar
I went and changed all plugs and coil packs and now i'm getting (3) misfires on cylinders 3, 6 and 8. Am I doing something wrong? Can you explain the procedure in case i'm missing something? Thanks.
Old 11-20-2018, 04:40 AM
Tstealth32's Avatar
Hmmmm. They come already gaped, so that shouldn't be an issue. Did you find any oil in the spark plug wells? wondering if some dripped down and caused a momentary misfire. Try to clear the codes and start it back up. As long as you felt the click of the harness and coils, you should be good, it's a very straight forward process.
I would:
Check to make sure you hooked everything up tightly: Coils, air intake, MAF
Clear codes
Try again
Old 11-20-2018, 04:49 AM
Basenco's Avatar
I would:
Clear codes
Try again
One thing I didn't do was to use my torque wrench to tighten each plug to spec. But I gave each one a 1/4 turn after if was snug. If I need to torque, what is the actual setting? I'll have to re-check everything this evening. Thanks.
Quick Reply: CHECK ENGINE LIGHT - FAULTS INCLUDED
