Curious remote issue
Old Oct 28, 2008 | 04:42 PM
eidderfliw's Avatar
New Member
Default Curious remote issue
For the past 2 years , the remote key has been working intermittently and of course, never would act up while at the dealership. It has gotten much worse recently. The problem is the remote function will not work at all, even if I am one foot away. I open the door manually and the remote will then work fine. Seems that after 5-6 hours is when it is now happening. It is now getting worse with the colder weather. I am being told by the dealer it is not part of the power management system, where components start shutting down if the system senses low voltage. I have changed keys and replaced batteries to no avail. It is an early vin 2004 A8L and is still under the CPO. Thanks for any info.
Old Oct 28, 2008 | 08:46 PM
MP4.2+6.0's Avatar
Tech Guru
Default My reactions:
1. It does sound like battery problems in the remote. My older heavily used remote has clearly lost range compared to my other untouched/still new remote.
2. The dealer may be wrong about the power management system, at least for keyless entry. Keyless entry definitely goes away at lower voltages from experience. I think I may remember if it gets really bad, it may need the actual key in the door cylinder, but haven't seen that so far.
Failing that, I guess if it isn't the key that leaves pretty much the receiver unit and antenna. You should look for TSB's on that.
Old Oct 29, 2008 | 09:50 AM
audi01a6's Avatar
Default Curious
what year,
Old Oct 29, 2008 | 11:00 AM
eidderfliw's Avatar
New Member
Default Re: Curious
It is a 2004.
Old Sep 16, 2021 | 08:20 AM
Goofpod's Avatar
Jon
Mar 22, 2004 08:36 AM
KarfisTTa
Jan 4, 2003 01:57 PM
Stang Guy
Mar 19, 2001 07:27 AM
bugbbq
Feb 27, 2001 05:25 AM
