Custom steering wheel is on!
Old Apr 22, 2013 | 07:41 PM
  #11
Lexdiamondz10304's Avatar
Originally Posted by STRKLDR
That looks excellent!!! Did you run into anything unexpected or rough with the steering wheel removal and installation? I got my car back from the body shop on Saturday and am going to install my custom steering wheel in the next couple of days. I have to put on my matte aluminum mirror bodies, too.
Thanks!
Joe
The installation is overall fairly easy. Just loosen up the two screws (don't remember the size) holding the airbag (note the screw covers in the picture I posted, they pop right off), you might want to turn the wheel 1/8th of a turn left and right to have enough clearance for the tools, while loosening the screws. Then disconnect the battery before you unplug the airbag connector. The center bolt was also fairly easy to remove. I used a 6-point T-50 bit with a 3/8th's drive ratchet and extension to remove it. Swapping the wheel should take about an hour at most. Just make sure when you go to torque the center bolt, have someone assist you by holding the wheel firmly so you don't brake the electric steering wheel lock. Good luck, and post pics when you're done. What kind of wheel did you get?
Old Apr 22, 2013 | 07:50 PM
  #12
Originally Posted by CobraCommander
Looks good! Who did the work on the wheel for you? Also what is your current wheel/tire setup? It looks good, any other pics?
I had the wheel customized by CraftCustoms in Texas. My wheel setup is 22x9 in front with a 10mm spacer, and 22x10.5 in the rear. My tires are Nitto Invo's, 255/30/22 in front and 275/30/22 in the rear.
Old Apr 22, 2013 | 08:03 PM
  #13
Originally Posted by tx170754
How did you added the wood trim ?
You know I was curious myself, on how they added the piano black trim. The wheel originally was all leather, and requested the gloss piano black trim to be added. By looking at the wheel, it looks like the encased the shape (glossy portions) with a type of resin, sanded/shaped it, and then painted it using urethane paint, something I could of easily done. The only thing was the leather re-wrap, so I let them do all the custom work. I really like the overall feel of the new steering wheel, the leather grain really makes it feel luxurious and alot more comfortable than the old wheel.
Old Apr 23, 2013 | 03:22 AM
  #14
tx170754's Avatar
What's the name of the company who did the job, please.
Old Apr 23, 2013 | 03:24 AM
  #15
tx170754's Avatar
Nevermind, I've got it.
Old Apr 23, 2013 | 03:51 PM
  #16
STRKLDR's Avatar
Mine is reshaped with a flat bottom and thicker wheel. I'm going to try and get it on in the next couple of days.
Old Apr 24, 2013 | 05:36 PM
  #17
CobraCommander's Avatar
Can't wait to see that mounted?...what did that run you if you don't mind sharing?
Old Apr 26, 2013 | 06:16 AM
  #18
dokebi1221's Avatar
Wow STRKLDR! That looks awesome...I'm very tempted to get that steering wheel...Where can I get that steering wheel?
I guess this is just an opinion, but do you guys think it will look silly on our D3?
Old Apr 26, 2013 | 02:14 PM
  #19
STRKLDR's Avatar
Default Carbon steering wheel is on!!!!
With the extended carbon shift paddles you're sitting around $2100.
I'll take better photos in better light next chance I get.
Joe
xxaudixx2510
Q7 MKII Discussion
20
Feb 22, 2019 12:03 PM
xxaudixx2510
Q7 MK 1 Discussion
Mar 17, 2018 07:11 PM
xxaudixx2510
New Member Welcome Area
Mar 17, 2018 01:18 PM
itiongo
Q7 MKII Discussion
9
Apr 30, 2017 11:52 AM
IronMike
May 27, 2003 10:31 PM
