D3 bleeding procedure
Old Apr 25, 2012 | 09:24 AM
A8CT's Avatar
Default D3 bleeding procedure
Do you guys think it takes an unusually long time to bleed the coolant system and get the thermostat to open?
Just changed the WP and thermostat and can't get the gauge to budge. I have the heat on high (it's hot) and both bleeder screws have coolant coming out. The top radiator hose is hot but the bottom is cold. Because the car thinks its overheating, both fans come on and are supercooling it at idle. Those fans throw an unreal amount of air...
I might have caused an airlock because I opened the bleeder screws after I added a bunch of coolant. I guess your supposed to open those first and then ADD. Car has run about 15 minutes so I'm starting to get worried that I might have a bad thermostat. I just re-opened the valves and cap and letting it sit for a while.
Bob
Old Apr 25, 2012 | 11:22 AM
A8CT's Avatar
weird but I'll take it. I ran the car again, fans ablaze and kept re-bleeding it but the gauge would not budge. I kept checking the coolant and block temp with my gun and knew it wasn't overheating so I figured the fans were on because the car thought it was low on coolant.
I went into measuring blocks to see what the temp really was but before I did that there was a code saying "engine temp too low".
Looked at the temp in vag-com and it was 92c which is just fine. After I did that, I looked down and the gauge was dead center. Is there some sort of adapation sequence I should have run? I've gone out a couple of times now and turned the key and the gauge still registers but getting lower as it cools.
So, vag-com woke up the gauge but I'm still not exactly sure what happened.
Bob
Old Sep 9, 2023 | 04:09 PM
tonyizzo's Avatar
Default What ended up being the problemv
Bob
hey what ended to being the problem
mike@fmc
Audi 100 / A6 (C4 Platform)
Jun 4, 2011 08:54 AM
cashguzzler
Audi Original "S" Cars
12
Nov 30, 2005 03:30 PM
eisman.s4
Nov 26, 2005 06:15 AM
dfinn
Oct 15, 2005 10:09 PM
Phantom
Dec 27, 2003 07:40 PM
