Engine Missfire
Old Jun 27, 2020 | 12:25 PM
francois6868's Avatar
Default Engine Missfire
Hello I just bought an audi s8 for not very expensive but in a bad state engine level, I can not find the fault, in fact the car does not turn round as if it did not turn on all these cylinders.
I have already done the necessary maintenance, namely new coils, new spark plugs, air filter, fuel filter, drain. A power steering return hose was tinkered, I redid it properly too. I disassembled the intake manifold there were broken intake manifold flap, and I deleted the flap, I also bought the lambda oxygen sensor corresponding to the bank 2 sensor 1 at Audi and I changed it. because I had the fault with the VCDS but the fault reappeared despite the new sensor. I have several faults in the engine computer 1 and engine computer 2 diag.
Here are the faults :
Engine control unit 1:
005715 - Read the fault memory of the ABS computer
P1653-008
006439 - Relay for Aux Coolant Pump (J496) Out of order
P1927-004
000081 - Oxygen (Lambda) Sensor B2 S1 heating circuit Short circuit to ground
P0051 - 002 - Intermittent - Indicator on
006435 - Read the fault memory of the engine control unit 2
P1923-008
Engine 2 computer:
P1653-008
000768 - Misfire detected
P0300 - 001 - Light on
000772 - Cylinder 4 Misfire detected
P0304 - 001 - Light on
000773 - Cylinder 5 Misfire detected
P0305 - 008
Knowing that the oxygen sensor in question that I changed corresponds well to cylinder 4 and 5 therefore the where I have misfires.
Thanks to you if you have an idea and sorry for my english i am French.
Glenn71
Audi A2
Apr 20, 2018 03:37 PM
Glenn71
Audi A2
Apr 11, 2017 01:08 PM
ajrdsr
Feb 23, 2014 05:16 PM
YucatanAudi
May 12, 2006 09:09 AM
liviutz
VAG-COM Discussion
Feb 3, 2005 05:52 AM
