Engine problem
Drove home and acceleration had bad misfire and rough running. Yellow engine light would flash when accelerating from a stop.
Added a can of B-12 and next morning it ran much better, but not fixed. Drove the 60 miles round trip to work and the yellow light flashed a few times, then stayed on. Rest set while at work, came on leaving the parking lot.
The car runs better when the check engine light is on. Sometimes feels normal. But idles rough on start.
Topped off with gas from another station and added another can of Berryman B-12. then ran these scans. Also made an appointment to Bar Tuning for Monday in case it does not fix itself with injector cleaner.
Does this look like a bad gas issue, or do es it appear to be a real problem
ddress 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number: AUX3Z0D8750390
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285FF7779BE9715EF37-807D
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
16685 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Readiness: 0010 0000
Sorry, the TXT file had three scans and is too big to upload. But this is the only result that was not normal. I idled the car for 20 minutes and scanned three times, the check engine light only flashes when accelerating. Idled like normal after the second can of B-12.
Coding: 0007773
2 Faults Found:
16685 - Cylinder 1
2) Most likely lost a coil pack. Swap another coilpack to cylinder 1 and see if the misfire follows. Bad gas will give you misfire on all 8.
3) That B-12 stuff won't do anything, I assume it was made to clean varnish off carb bowls. If you're looking for an injector cleaner that will actually do something on modern cars, it has to contain Polyether amine (PEA). Chevron technron and 3m both make one.
Have not driven since. I should be back tomorrow evening. Will try a round the block before going to far.
Your description of the loping idle at one point also caused me to think about the cam sensors, but you didn't show/indicate any codes for that. Most generally, figure it is probably ignition, but could also be in some other sensors for ignition or general engine. VAG COM should point to the latter, which it doesn't seem like so far.
Here is the link to the site for both parts:
AutohausAZ - Ignition coil
AutohausAZ - Spark plugs
Disclaimer: Make sure to check the year and model of the vehicle before placing an order.
I will test drive tomorrow night. It still acting up I will take it in Monday to get a local mechanic.
On the possible recall on coils, should I ask dealer over phone? I have a 200.00 key on order from them.
2. Try contacting Audi USA: Audi Customer Service - Contact Audi | Audi USA There used to be an open service action look up on their web site at http://www.audiusa.com/us/brand/en/o...in_lookup.html, but I don't see that now. You could mention that to them on the phone.
3. Try looking under the hood for a campaign sticker; mine has a quite small yellow colored stick on label.
