help
Old Mar 19, 2008 | 04:10 PM
nimo's Avatar
New Member
Default help
i want to put hid's on my fog lights to match the hids on head lights any one know what type of bulbs are ine the 2007 audi a8 is it h7? and do you recommends what company for these bulbs... also im thinking of putting on 2008 tail lights anyone know how much they run or where i can get them a lil cheaper than factory.
Old Mar 19, 2008 | 05:03 PM
A4xIV / Nadroj's Avatar
oempl.us for tail lights. 1k+
Old Mar 19, 2008 | 06:55 PM
nimo's Avatar
New Member
Default s8 grill for 07 a8L
u guys know a place where i can get an official s8 grill at a reasonable price?
Old Mar 19, 2008 | 07:44 PM
MP4.2+6.0's Avatar
Tech Guru
Default It's an H7 but...
having thought about this myself, I am concerned about the cornering light function that also uses the fogs, at least on my car. I suspect that may have a dimming sort of feature to it--seems like a "soft" turn on and turn off like a dimmer may be involved. Need to investigate more. If so, that could not sit well with true HID's that presumably want full voltage into their ballast pack. The sudden "flash" type light off that HID's have may also startle people when the cornering light kicks in, part of the reason I suspect it may have a dimming type gradual on design.
Meanwhile, I use the 65W Osram H7's. Color is good and wattage seems w/in range of fusing and wire guage still. I only use fogs now when needed, so I'm not so much into styling as I am into general function. Supposedly these are 2100 lumens vs. 14-1500 lumens for a standard 55w H7. Search on Osram 65W or Hoen for higher performance bulb info.
Old Mar 19, 2008 | 10:31 PM
Der Kimbo's Avatar
Default Neither the dynamic cornering lights or the static turning lights use the fogs.
The big issue is the fog light unit on the '05 and up. The beam pattern will blind the living hell out of everyone. If it was an '04 with the projector fog's I'd say go for it.
Old Mar 20, 2008 | 04:34 AM
mikesd1980's Avatar
I have a 04. How hard is it to change the fog light bulbs? Anybody know how?
Old Mar 20, 2008 | 08:50 AM
CovertW12's Avatar
Default Try Rich at oempl or Craig at GenuineAuidvwparts
both have been great to work with in my buildup - providing solid knowledge and great pricing.
regards,
Old Mar 20, 2008 | 10:01 AM
Der Kimbo's Avatar
Default Pull the lower grills out, remove the fog lamp assembly, replace bulb...
04's use an H10 or H11 bulb IIRC.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 20, 2008 | 02:35 PM
nimo's Avatar
New Member
Default Re: It's an H7 but...
<center><img src="http://pictureposter.audiworld.com/137595/n6809415_41720919_9097.jpg"></center><p>i was thinking of putting a whole hid conversion in but i dont want it to trigger the computer so that i get faulty bulb signs all the time when i drive or use them. cuz they arent oem.
Old Mar 20, 2008 | 02:37 PM
nimo's Avatar
New Member
<center><img src="http://pictureposter.audiworld.com/137595/n6809415_41720919_9097.jpg"></center><p>ALSO its wierd on my 07 a8 the cornering light is in the headlight not in the fog light did u double check on urs? with ur friend waiting outside watching
