Sponsored by:
Sponsored by:
Q about Head Light Range Control warning light....
Old 01-19-2018, 03:37 PM
awdinut's Avatar
Default Q about Head Light Range Control warning light....
Has anyone known of the Head Light Range Control Module (4F0 907 357 E) to be the cause of loss of Static Cornering Light and Self Leveling Function motion check in a headlight ? And where is the module located ?
A used one is only $35 so it would be a cheap fix to try first, if it is accessible. I f I knew where it's located I would try swapping it out before I went and took the front bumper off th get the headlight out to look trouble shoot the leveling motor.
Old 01-19-2018, 04:31 PM
Giovanni Giovino 6.0+6.0TT's Avatar
Hello Awdinut,
The part number should be "4E0" not "4F0", and as it has the front parking beeper attached to it, listen for the beeping to locate where it is, I do not recall at the moment, and it is cold outside....
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 02311 785 00200
VCID: E2CF2EBB416B
No fault code found.
Attached Thumbnails Q about Head Light  Range Control warning light....-s-l1600jfgjhjm-d.jpg
Old 01-19-2018, 04:45 PM
Okay,
I could not leave you hanging like that, so I went out into the cold and found it, it is directly behind the instrument cluster, dead center.
Attached Thumbnails Q about Head Light  Range Control warning light....-20180119_203957.jpg   Q about Head Light  Range Control warning light....-20180119_204007.jpg   Q about Head Light  Range Control warning light....-20180119_204020.jpg
Old 01-19-2018, 07:55 PM
awdinut's Avatar
Thanks, you saved me a lot of valuable investigative time ! When you said it had the Parktronic beeper (why ?) I figured it would , unfortunately, have to be behind the cluster. But, a cluster R&R is easier than a bumper and headlight R&R, so I will try the module first.
Old 01-20-2018, 06:59 AM
awdinut's Avatar
Default would this error code indicate the module as the culprit...
Originally Posted by Giovanni Giovino 6.0+6.0TT
Hello Awdinut,
Coding: 0000004
VCID: E2CF2EBB416B
The scan says "RIGHT HEADLIGHT POWER OUTPUT STAGE (J668) 004 NO SIGNAL/COMMUNICATION-MIL ON"
DG94
Audi allroad
09-06-2007 09:57 AM
HugeTTs
03-25-2006 04:59 AM
Maverick2026
VAG-COM Discussion
10-06-2005 02:56 PM
gr7hug
12-13-2003 08:42 AM
garyP
Audi 100 / A6 (C4 Platform)
03-25-2002 10:23 AM
Quick Reply: Q about Head Light Range Control warning light....
