parking sensor intermitent
Old Feb 6, 2019 | 09:33 AM
audijim113's Avatar
Default parking sensor intermitent
I know it's a PITA to replace a parking sensor but wondering if it's possible to access the connector? My sensor graphic works sometimes, and sometimes not. Middle left rear sensor shows up as faulty on a scan. Depending on temperature, the graphic and beep works. It hadn't worked at all for last 4-5 months and when the temps got really cold, it started working again (about 50% of the time).
I'd love to unplug and reconnect the sensor because it seems like a flaky connection.
Is there anyway to get at it without pulling the rear bumper cover off?
Old Feb 6, 2019 | 01:36 PM
ScottCNelson's Avatar
Necromancer
Why do you think its hard to access the parking sensors? The rear ones are simply a matter of looking/reaching behind the bumper with no disassembly required. I replaced one near the left rear muffler in 10 minutes. FYI, I've seen used wiring harnesses all over eBay for cheap. The parking sensors themselves go for about $10.
Old Feb 6, 2019 | 03:28 PM
dvs_dave's Avatar
AudiWorld Wiseguy
The front outer ones are easy to swap also.
Old Feb 10, 2019 | 12:55 PM
audijim113's Avatar
Videos I've seen require the bumper cover to be pulled off. Or at last partially pulled. The one that shows up as bad is my rear, middle left. I even purchased the sensor (yes, cheap) but haven't gotten around to replacing because I thought my hand would never fit in there to reach it.
Love your photo. Brings back memories. While I'm sure this dual wheel Mercedes is on a truck chassis with a diesel, it resembles a 1953 220 gas model sedan I bought when in 1964. (I was 19 and paid $35 bucks for it). It ran, but knocked. I thought about dropping a small block Chevy V8 in it but frame was too narrow so rebuilt the 220. It was neat with suicide doors. Wish I still had it.
Kevin Gunn
Q5/SQ5 MKII Discussion
31
Oct 26, 2025 03:03 PM
Sci-fi_Wasabi
Jan 17, 2021 08:48 AM
hanilanzi
Nov 1, 2012 07:48 AM
bydecebalus
Sep 28, 2009 02:24 PM
711woods
VAG-COM Discussion
Aug 18, 2006 05:58 AM
