Practical experience re-coding features with VAG COM?
Old May 10, 2007 | 02:12 PM
MP4.2+6.0's Avatar
Tech Guru
Default Practical experience re-coding features with VAG COM?
Does anyone currently on the board have experience using VAG-COM to recode features on the D3? (aside from the suspension where there are recent posts) For example, instrument lighting, alarm chirp, window roll down and up using the remote, etc.
Searching the archives, the information is sketchy. Looking through things last night with a VAG-COM hooked up, I can see the same kind of soft codes and general settings as on my C5. Plus a lot of new stuff of course that wasn't around for a C5.
So far, I reset the instrument lighting so the guages are fully backlit by day (the default setting seemed to be only limited backlighting with lit needles). I also eliminated the seat belt chime (I think). Next up are trying to get the window roll down and up tied into the remote--the car setting is just to let this be done through the drivers window switch panel when the car is off. I think I see where the setting is, though how it ties into the MMI adjustability of the feature through the door window switch isn't clear from any sources I could find--RossTech's site and Wiki and open obd. I'm also going to try to get it to drop the alarm chirp and just use the lights blinking as the arming cue.
It's also clear where the trip computer gas consumption adjustment is, but so far it seems pretty accurate from measuring miles against actually gallons pumped.
Anyone on the board delved into these on the D3?
Old May 10, 2007 | 11:51 PM
MP4.2+6.0's Avatar
Tech Guru
Default Confirming things I was able to recode tonight
Previously:
1. Coded instrument lighting to show guages (and needles) fully illuminated by day.
2. Eliminated seat belt warning chime.
New:
3. Coded window feature controlled by door drvers window switch so it also closes the windows (normal setting only opened mine). Also added sunroof to the things closed by this feature, but not opened.
4. Enabled remote to open all windows by holding down unlock button, and to close all windows and sunroof by holding down lock button
5. Deleted alarm chirp, leaving flashing lights as the signal.
##3-5 Done using the recode and adaptation features in the Central Convenience group [46] with VAG-COM. ##1 and 2 were done with a recode in the Instruments group [17].
Old May 11, 2007 | 07:00 PM
jsdkms's Avatar
New Member
Default Re: Practical experience re-coding features with VAG COM?
Thanks for the info! Please keep us posted on your progress! Maybe you could find a way to turn off the passenger air bag light?
Old May 14, 2007 | 06:37 AM
lefteris_gr's Avatar
New Member
I enabled the Daylight Running Lights - no country code change needed.
Old May 15, 2007 | 08:25 PM
geordie's Avatar
It's called black tape over the light. Can't be switched off
Old May 18, 2007 | 10:16 AM
MP4.2+6.0's Avatar
Tech Guru
Done via MMI on my car
awdinut
Jun 5, 2013 12:46 PM
CSavage
VAG-COM Discussion
14
Nov 28, 2011 09:44 AM
B56
17
Nov 29, 2008 08:25 PM
MP4.2+6.0
VAG-COM Discussion
May 11, 2007 03:55 AM
MP
Aug 8, 2003 12:44 PM
