strange problem
Old Jul 2, 2017 | 03:25 PM
audi-v8's Avatar
Default strange problem
hi
i have audi a8L 04 i got problem which is if i refuel tank the car become vibration and wont
drive away even when i try to drive like this
but if the tank is low or quarter it become good and i can drive comfortably what kind of this problem
Old Jul 2, 2017 | 03:34 PM
Jack88's Avatar
First step is to do a VCDS scan, see what kinds of codes the car has. Does it run any better with the gas cap removed?
Old Jul 2, 2017 | 03:42 PM
audi-v8's Avatar
i did scan or computer check there is no codes about gas cap but yes you right
i refueled the tank a little bit more than quarter with the door of tank is open its better
but sometimes when i slow speed car is stoped then start it again like this
about the codes i got this
18265
load signal :error
message from ecu
p1857
thx
Old Jul 2, 2017 | 04:14 PM
audi-v8's Avatar
this the scan codes
Old Jul 2, 2017 | 04:41 PM
Jack88's Avatar
Try unplugging your mass airflow sensor when running poorly and see if that smooths it out any.
Old Jul 2, 2017 | 04:49 PM
audi-v8's Avatar
you mean remove airmass sensor and running the car right??
ok what about the gas fill it or no
Old Jul 2, 2017 | 06:39 PM
Jack88's Avatar
When the car is running poorly, open the hood and unplug that sensor. If it smooths out, that would point to a fault with that sensor. Shouldn't be related to the fuel level, but the error you are getting seems to have been related to the MAF in other cases. These cars are complicated, so I would at least try this to rule it out.
Old Jul 2, 2017 | 09:55 PM
audi-v8's Avatar
Thanks for your response i will try and i will come back
 Pouria Savadkouei
 Michael S. Palmer
Jorge Aguilera
Audi allroad
Jul 5, 2017 02:04 AM
2mass
Dec 31, 2004 05:50 PM
EdLove
Nov 7, 2004 03:59 PM
phkodack
Mar 6, 2002 09:58 PM
tsb4
Aug 27, 2001 04:40 PM
