Unsolved Mysteries - Dash Rattle
Old Apr 13, 2009 | 07:02 AM
parnyc's Avatar
Default Unsolved Mysteries - Dash Rattle
bought a cpo '04 A8L in december and have had an annoying rattle or vibration in center of dash since beginning. its pretty subtle and generally only hear it on rough roads but it's driving me crazy. have taken it to dealer SIX times to figure out the problem. they have practically taken entire dash apart and said they found a loose screw and bracket, and have installed cushioned tape all over, but nothing works. if anyone has dealt with this problem, i'd really appreciate some insights.
..also, car suffers from same intermittent starting problems that seem to be pretty common on this forum. seems like there might be a TSB for the problem. if anyone has it, please send along.
many thanks.
Old Apr 13, 2009 | 07:49 AM
Rowlie's Avatar
I had a rattle in the center of my dash which ended up being from the aluminum trim below the mmi screen. It stopped when I put my hand on it. The dealer reseated the trim and I haven't had any problems since.
Does yours stop if you push on anything?
I've got the intermittent starting problem, but haven't heard of a TSB on it. I guess we're supposed to wait until the starter fails.
Old Apr 13, 2009 | 07:56 AM
parnyc's Avatar
thanks. nope..I tried pushing down on all areas of dash.
re starting, yeah I'm sure mine will fail when I'm in the middle of nowhere.
Old Apr 13, 2009 | 08:55 AM
lgball's Avatar
25 Year Member
Try the cowling under the hood. I had that rattle as well and it turned out to be the plastic cowling just in front of the windshield. Sounded like it was in the dash, but it wasn't.
SD
Old Apr 13, 2009 | 09:52 AM
parnyc's Avatar
thanks...will check. did you ultimately have to replace it and take out the windshield, etc?
Old Apr 13, 2009 | 02:30 PM
bac2h's Avatar
Ace Ventura
Default Yup..that's what happened with mine too...dealer fixed it N/C...I was stunned!!
SD
Old Apr 14, 2009 | 07:01 AM
all-go no-show's Avatar
Default I had a rattle too....
It ended up being the emergecy sunroof closing tool that was loose in the fuse compartment. Try taking a look in there.
Old Apr 14, 2009 | 10:32 AM
dalep's Avatar
Default Does it rattle when...
The MMI screen is closed. These sometimes rattle when open,but not when closed
Old Apr 14, 2009 | 01:22 PM
lgball's Avatar
25 Year Member
No - they were just able to stop the rattle somehow without changing anything. Mine is rattling again, but I have traced it to the MMI screen as discussed in a few posts above. If the screen is closed, no rattle, open, sometimes it rattles, sometimes it doesn't.
Grrrrrr. I hate rattles.
Old Apr 15, 2009 | 07:36 AM
parnyc's Avatar
Mine rattles regardless of whether MMI is open or closed. Will take a look a cowl. This is torture!
