What oil to use?
Tell Galo I sent you and he'll treat you right! He'll also know exactly what you need and quantity. I'd get Fuel Filter, Air Filter, Oil Filter, Cabin Filter & also the Spark Plugs while you're at it. Wouldn't hurt to have them on Hand when time comes.
http://www.bgprod.com/products/engineoil.html
Add the MOA to your Oil.
http://www.bgprod.com/products/fuelair.html
Add the 44K to your Fuel.
You'll have to shop the Net to Find them and they are Pricey but well worth it! Take care and laters,
The MOA can be used in 2 different ways. You can add it to your Next Oil Change by substituting an = amount of Oil for 1 Can of MOA and call it a Day. You use MOA as a Flush prior to doing an Oil Change by Draining an = amount of Oil and replacing that with MOA then Drive as instructed followed by the Oil Change. Just add the MOA subtracting an Equal amount of Oil. At next Fill Up just add the 44K to the Tank and Fill it up as Usual. It takes about a Half of a Tank of Fuel before you Start to Notice, but I would also change the Fuel Filter.
After careful research and considerations I chose Fuchs 5W30 if I remember correctly without looking. It is German Born and Bread for German Automobiles like the A8 so I had no Problems using this Oil. Hope this helps you Brozee. Take care and laters,
As for fuel mileage, I find additives to be a waste except maybe for cleaning purposes. A couple of years ago I did several experimants between regular and premium fuel in my A8 (4.2L) to see what the best value was. Performance difference was unnoticeable by me but the main reason for the comparison was some claimed way better fuel eCONomy with premium. I did not detect anything close to being worth 20¢ a gallon more. I believe most drive differently. I drive quite the same route and speeds so my test was fairly accurate. EPA tests would be more CONsistent though.
As a kid, I added a J. C. Whitney glass fuel filter that you could take apart to my '74 VW Super Beetle. When I worked at Zieger Hospital in Detroit, one day I came out of work in the bitter cold and "no start". I opened the engine compartment and the fuel filter was a block of ice. The day before I filled up at a Thornton (not Melon) station. Big mistake as I went there to save a few pennies a gallon. Didn't know they put a *secret additive* in their fuel tanks.
I didn't use Premium either after being told by Audi Service Manager that you wouldn't suffer much performance, so I used Mid Grade until the MOA Treatment and may go back to Mid Grade soon based on Gas Price.
