02 sensor?
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [096] - too Lean
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 114872 km
Date: 2023.05.24
Time: 07:13:55
Engine RPM: 1493.50 /min
Normed load value: 20.8 %
Vehicle speed: 59 km/h
Coolant temperature: 60 �C
Intake air temperature: 26 �C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.758 V
Unlearning counter according OBD: 8
Rear cat conv temp main cat conv model value: 461.24 �C
O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean: 0.09 s
O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich: 0.19 s
O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean: 0.00 s
O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich: 0.34 s
Thoughts on this? is it an exhaust leak somewhere or do I have a sensor I need to replace?
If so which one?
I cleared the codes - should I wait a few more days of driving to see if it pops up?
thx
@MP4.2+6.0 - any thoughts on this?
I cleared the code and noticed that it returns again not too long after filling up petrol. I now ensure that I use Esso super fuel or the best fuel at the pump and rarely see this code again. I once forgot and used normal unleaded and it came back very quickly.
I would say clear the code and see if it makes a difference where you get fuel from. It's worth a try and it's free!
