Differential module position
Old Jan 25, 2021 | 04:39 AM
Hristomir's Avatar
Default Differential module position
Please can someone help me find where the 4wd control module is on my audi a8 d4 2010 4.2 tdi. The module part number is: 4h0 907 163
Thanks in advance
Old Jan 25, 2021 | 07:08 AM
virtualrc's Avatar
Moderator
I think this module is located in the trunk, left side spare wheel well.
Old Jan 25, 2021 | 07:55 AM
Hristomir's Avatar
I've looked everywhere for it but couldn't find it 😔
Old Jan 25, 2021 | 08:33 AM
virtualrc's Avatar
Moderator
You need to look under the trunk floor, peel back the carpet underneath the spare tire.
Old Jan 25, 2021 | 01:46 PM
MP4.2+6.0's Avatar
Tech Guru
Just confirming, you mean for a sport differential option set up, correct? If it is conventional rear diff and Quattro, there should not be any control module. All mechanical in that case AFAIK.
Old Jan 25, 2021 | 05:21 PM
2turbos4rings's Avatar
W12 Aficionado
The best way to access it is to remove the left side trunk wall/liner then lift the left rear corner of the bottom carpet/trim and you’ll see it in the spare tire well.
Ivan Blagoev
Nov 15, 2020 10:45 PM
Mikelopeza90
New Member Welcome Area
Feb 1, 2019 06:00 AM
A8CT
May 2, 2012 06:03 AM
sparkster
Jun 2, 2011 07:09 AM
Dr Chill
Q7 MK 1 Discussion
Dec 7, 2006 12:36 PM
