Motor Mount Code Question
Old Sep 27, 2024 | 07:20 PM
Burkeomatic's Avatar
Default Motor Mount Code Question
I'm trying to figure out what this non-sense is with my motor mount codes. I'm fairly certain one of them is bad, but I don't think that's what this means (not what it looked like on my C7). It says no basic setting, I have a sneaking suspicion that someone deleted something either in an effort to clear a CEL or hide it. Not sure. Ideas? I have a SRM metal one for the passenger side on the way.
Code:
2 Faults Found:
0554 - No Basic Setting
          B2010 00 [00001001] - -
          [FC_AssemblyCheck_NotDone]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 140921 km
                    Date: 2024.08.21
                    Time: 19:45:35
1632 - invalid data record
          B2005 00 [00001001] - -
          [FC_Dataset_Invalid]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 140921 km
                    Date: 2024.08.21
                    Time: 19:45:35
Old Sep 30, 2024 | 09:59 AM
EricVonHa's Avatar
Your intuition is probably correct. The BA module probably needs to be re-coded to the car.
Can you access the output test for the motor mounts?
Old Sep 30, 2024 | 04:50 PM
I'll figure out how to do it and give it a shot. I just had to take it back to the shop that did the warranty suspension work because the ball joints were still clunking and creaking. It looked like they reused the bolts... ugh.
Old Oct 1, 2024 | 05:59 AM
EricVonHa's Avatar
It's the 2nd tab in the recent version of VCDS under "installed" modules. Look for motor mounts (obviously..)
The tone from both mounts should be the same.
These things usually fail from breaking apart and cracking and leaking some nasty goop. You'll usually see it if this is the case.
F03
Audi A5 / S5 / RS5 (B9)
Mar 17, 2024 01:28 PM
quattro_demon
Apr 8, 2023 07:51 PM
DallasDave
51
Nov 9, 2021 05:29 PM
Mrdeli
VAG-COM Discussion
Jul 8, 2012 03:00 AM
mj2.7
Apr 11, 2002 10:01 AM
