Is 5bar normal while driving??
Old Nov 18, 2004 | 06:02 AM
S6Q's Avatar
S6Q
New Member
Default Is 5bar normal while driving??
i was just wondering what the normal operating ranges were.
Old Nov 18, 2004 | 08:26 AM
djdc's Avatar
Default Re: Is 5bar normal while driving??
I would say so. Thats about what i run at when driving.
Old Nov 18, 2004 | 08:29 AM
Mr. Malcontent's Avatar
that's where mine runs.
Old Nov 18, 2004 | 08:57 AM
S6Q's Avatar
S6Q
New Member
cool i thought i was right, had a service man tell that it was a problem
Old Nov 18, 2004 | 10:02 AM
A6Gary's Avatar
Default If your oil pressure sensor is located in the upper oil pan, the OEM spec range is...
* At idle: 1.0 - 2.5 bar (14.5 - 36 psi)
* At 3000 RPM: 3.0 - 5.0 bar (44 - 73 psi)
If your oil pressure sensor is located on cylinder head, the OEM spec range is:
* At 3000 RPM: 2.7 - 2.9 bar (39 - 42 psi)
Note:
* With the pressure relief valve in each cylinder head, a lower oil pressure is registered in the cylinder head than is actually controlled by the oil pressure control valve.
* Oil pressure sensor/switch: 0 - 3/0.3 bar
* Oil pressure indication: 0 - 5 bar
These specs are from the Bentley Manual. Your mechanic may have been confused by the two separate layouts.
Old Nov 18, 2004 | 04:31 PM
Muhammad's Avatar
5 bar at startup, mine drops to 2 bar at warm idle. 5 bar on load.
Old Nov 18, 2004 | 11:32 PM
snowman '92 100's Avatar
2nd
Mr. Malcontent
Audi 100 / A6 (C4 Platform)
Feb 20, 2007 07:06 AM
Ben's e//S2
Sep 19, 2005 06:24 PM
Daedalus
12v V6 Discussion
Aug 5, 2004 11:08 AM
Me_and_my_GT
Apr 25, 2004 10:43 AM
Muhammad
Feb 16, 2003 05:38 PM
