A6 FWD Front shock/strut cartridge - big problems
I have used Bentley together with the many archived posts and have finally, after 2 hours and with the of a MAPP torch, a chisel and 5 lb hammer, followed by an 18" pipe wrench with 2ft of pipe extension, got the lower 'nut' off. Removing the three upper flange nuts released the shock cartridge which, as expected, slammed against the tower. However, after two more hours, I still cannot lift the shock out. Perhaps this is because I also cannot remove the sideways pressure from the cartridge, and I have tried all positions of the steering wheel together with various jacking height positions. In a word: HELP!
You may be able to use your jack depending on which way it is cramped and put your jack in the fender well to crank it back to positon it, or get a spring compressor from autozone
I still cannot extract the shock body. I have hammered what little I can see of it with a chisel, and applied WD40, but so far, its like its welded in place! Still marooned!
This is a bit off the wall, but how about attaching a slide hammer to the top of the strut and slamming it upwards to see if it can be shocked free. If this isn't it, then it's blue wrench (torch) time.
If it is really messed up, maybe get a used housing and swap
The issue in this gas is that it seems the strut cartridge is REALLY stuck in that housing
Hey Limey, how is the progress on this? Any chance the strut housing got 'dinged' and is pinching the cartridge in place?
I am fortunate enough to have a Audi parts guy near me from rent me his when I bought the struts from him
Try the local stealership, maybe they will rent out tools?
The car is on a chassis lift, with a jack stand under the steering knuckle.
Raise the body of the car so that the spring is near max extension.
Undo the nut that you got off of the strut body.
Shoot the shock body full of WD40 (just in case)
Lower the car some until the strut rod pokes well above the shock tower.
Re-attach the strut bearing to the top of the strut rod with the 22mm nut.
Raise the car on the lift, leaving the spring to push the cartridge out of the strut.
You basically use the power of the spring to top out the cartridge (maximum extension) and jerk it out of the strut body. Once it is free, lower the car on the lift a bit and then remove the strut and strut bearing from the top of the car.
Good luck, buddy!
Good luck, buddy!<ul><li><a href="http://www.hembrook.com/automotive/audi/100/suspension/index.html">Have a look at my procedure</a></li></ul>
