Any ideas on cause of wheel squeeking?
Old Aug 19, 2003 | 04:43 PM
greenaudi100's Avatar
Default Any ideas on cause of wheel squeeking?
I dont know if something needs to be adjusted with my brakes or what, but its a non stop squeeking you can hear with the windows down and its drivin me nuts!!! Does anybody have an idea what my problem is or experienced this before??? Thanks very much.
Old Aug 19, 2003 | 04:51 PM
bl98263's Avatar
does it stops when you press on brakes even a little bit?
Old Aug 19, 2003 | 07:13 PM
Default Re: does it stops when you press...yes but... (more)
Yes, when I tap the brakes just a little bit it stops, only for the brakes to start squeeking in the rear. But they are two distinct sounds. Not to mention I have new rotors and pads. When I first got the car there was not the driving squeeking coming from the front passenger side tire, I think, might be the rear or both. There was also no braking squeek at all. I want my car to have the new feel to it and it seems when I drive or brake it just sounds like an old audi with really bad brakes. I'm kinda stuck on what to do. Thanks for the help!!!
Old Aug 20, 2003 | 01:58 AM
imo46's Avatar
New Member
Check if they replaced the brake clips in the front,And that they mounted the rear ones correct.The rear brakes could have moved and sitting at angle.
Old Aug 20, 2003 | 08:05 AM
will do, thanks alot for the help!!!
Old Aug 20, 2003 | 01:28 PM
Carped1em's Avatar
New Member
I had squeeking rear brakes, when those pin bolts was stuck, after that it was gone.
Old Aug 21, 2003 | 06:26 AM
jnormandeau(93100CSQuattro)'s Avatar
New Member
Had same problem -> anti-squeal grease worked for me
Old Aug 21, 2003 | 08:23 PM
Where do I get anti squeal grease??? Thanks a lot!!!!
Angelasahni2015
New Member Welcome Area
Jun 13, 2019 07:40 AM
crusininda944
Audi 100 / A6 (C4 Platform)
17
Nov 24, 2008 09:16 AM
xtreetoes
Audi allroad
Apr 28, 2005 05:08 AM
dk8019
Nov 15, 2003 05:34 PM
swichlaw
Mar 10, 2003 10:58 AM
