Audi A6 2.5L TDI (AEL engine)
Old Sep 7, 2003 | 09:10 AM
TDIQ's Avatar
New Member
Default Audi A6 2.5L TDI (AEL engine)
I am doing a gas to TDI conversion.
And in need of a wire diagram of a 2.5L TDI (AEL) engine out of a 1997 A6.
Anyone know where I can find one?
thanks
ed
Old Sep 9, 2003 | 05:30 AM
Edd W's Avatar
Default Re: Audi A6 2.5L TDI (AEL engine)
I would try and get the complete front loom from the car the engine came out of. This should then go right back to the fuse panel. The plugs for the engine should then be obvious because they will be the right length.
Old Sep 9, 2003 | 04:04 PM
TDIQ's Avatar
New Member
I have the complete front loom
but it is going into a 86 4000cs quattro
so none of the plugs match.
82 Diesel Vanagon 5 speed
86 Turbo diesel Jetta 6 speed
86 4000cs Quattro (hopefully with 2.5L TDI this winter)
74 914 2.0
76 2002
Old Sep 10, 2003 | 06:29 AM
Edd W's Avatar
Default So, you must have the 5cyl, not the V6?......
I would try and find a totalled A6 2.5td "red i" and get the loom from that?
You will need to re-calibrate the settings on the back of the instrument cluster in the dash as well - there is a small slider switch to select which engine is fitted I think?
nishantanu
A6 (C7 Platform) Discussion
Feb 7, 2018 03:53 PM
1guitar
2.0T FSI Discussion
Sep 18, 2017 04:29 AM
Rusty Spokes
12v V6 Discussion
May 29, 2015 09:06 AM
syazwara@hotmail.com
Performance and Tuning
Jun 24, 2009 11:43 PM
spydervr4
Aug 22, 2007 02:33 PM
