Batter drain with humming noise under dash
Old Jul 8, 2009 | 10:23 AM
rpowers46's Avatar
Default Batter drain with humming noise under dash
1992 100CS.My battery is draining and it load tests out OK.When charging the battery and everything turned off in the car I am getting an on/off humming sound from the underside of the dash far left side.Each time it hums the batt charger shows additional charge so I know this is what is draining batt.I pulled all fuses out one at a time and humming did not stop I pounded on the spot under the dash and the humming quit.Battery stayed up OK.Any ideas as to what the is running causing the humming and batt drain?Thanks,Ron
Old Jul 8, 2009 | 01:59 PM
Ben2's Avatar
I think it could be the power window relay, I've heard of them sticking in the window up position. Next time roll the windows down and see if the humming causes them to go back up.
Alternately you could try taking each relay out one by one in the box under the hood right above the driver's side footwell.
If that doesn't work, I'd try asking on quattroworld.com, there seems to be a lot more knowledgeable people there.
Jadelyoness
Aug 19, 2017 08:00 AM
Astronut
18
Apr 6, 2007 02:08 PM
T0M3K
18
Mar 31, 2007 06:22 AM
Torcida
Jan 31, 2005 04:02 PM
BKChic
Oct 8, 2003 09:35 AM
