Best way to clean/degrease my engine?
Old May 8, 2007 | 08:19 PM
Biscuit141's Avatar
Junior Member
Default Best way to clean/degrease my engine?
Now that its nice out and I drive with my windows down I can smell all the grease and grime that has built up on my engine over the years as it gets hot. I want to spray it down top and bottom (on the heavy spots at least) with engine degreaser and then wash it off with a garden hose.
And yes I do have a few minor leaks here and there, no big deal, but I also hope this may show me where they are.
Does this sound like a good idea? Any better solutions and please no one say keep my windows up
Old May 8, 2007 | 08:26 PM
A6Gary's Avatar
Default Here's a link to a posting of mine re: engine cleaning...
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/67182.phtml">Clicky</a></li></ul>
Old May 8, 2007 | 09:04 PM
Biscuit141's Avatar
Junior Member
Default Ah, I remember this post. I was just making sure I wouldn't get water in anything and damage the
engine.
Old May 8, 2007 | 09:33 PM
Bmthorn's Avatar
Member
Cover up the wire harnesses you can see and don't spray water directly on them.
Old May 8, 2007 | 09:39 PM
Biscuit141's Avatar
Junior Member
OK I'll be careful on the top, it mostly the bottom anyway.
Old May 8, 2007 | 10:45 PM
ryanwindsor's Avatar
New Member
Default Dont pressure wash !
I did the mistake of doing that last year, I did covere the electrical components but still water will get to broken insulation on harnesses , and many other places you dont want water . I would Wipe clean with hot water and degreaser , dont use so much degreaser and make sure you wipe all of it of , the smell of it burning is really nasty . Good luck!
Old May 9, 2007 | 03:59 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default If you can smell "grease and grime" Something is leaking.
Wash the engine with Gunk or Simple Green or something, then look for the leak. Got Quat? Start looking for the leak at the tailshaft seal on the trans.
Old May 9, 2007 | 12:56 PM
austinado16's Avatar
Default I power wash just the lower areas after hitting them with Simple Green.
Anything up top, I do with carb cleaner and put some cardboard underneath to catch all the crud.
 Michael S. Palmer
paperlion81
Oct 25, 2012 03:46 AM
EricD88
Jun 29, 2005 02:50 PM
dvdkey
Audi allroad
Jan 3, 2005 08:19 AM
zeroS4
15
Jun 4, 2001 04:44 PM
S4Del
Oct 17, 2000 02:31 PM
