CC Codes...
Old Oct 16, 2004 | 03:16 PM
quattro2turbo's Avatar
Default CC Codes...
Hello all,
I have these 3 codes comming up - 11.4, 15.7 & 17.0
I know what they all mean via the FAQ but I was wondering if anyone could help me fix them.. Thanks in advance for any help..
-Marc
Old Oct 17, 2004 | 08:04 AM
AUDIrageous's Avatar
Default Try disconnecting the battery for about an hour.
Try disconnecting the battery for about an hour. That seems to reset all the electrical stuff. Be sure to have the radio code before you do it because the radio will go into safe mode and you'll need to unlock it.
Old Oct 17, 2004 | 10:20 AM
beep-beep's Avatar
25 Year Member
if "fix" mean clear - you can search for a person with VAG tool in your area.
Old Oct 17, 2004 | 10:45 AM
Default Re: if "fix" mean clear - you can search for a person with VAG tool in your area.
When they are cleared doesn't that mean the problem goes away?
If not, what can I do to fix these three problems? tia
Old Oct 17, 2004 | 06:41 PM
Anyone?
Old Oct 17, 2004 | 07:39 PM
beep-beep's Avatar
25 Year Member
Default what are the descriptions?
If you clear codes, but problem present. These codes will reappear in short period of time. If problem is fixed - the codes will not reapear. If would be nice of you to print description of codes, so we will not need to go though the list ourself.
Old Oct 19, 2004 | 08:25 AM
Default Re: what are the descriptions?
OK sure thanks for your help...
15.7 Air Flow Flap, sporadic block
11.5 Central Flap, static block
*11.5 Motor is cycled; software attempts to eliminate block
17.0 Vehicle Speed Signal faulty
Old Oct 20, 2004 | 09:04 AM
any advice beep-beep?
 Michael S. Palmer
Ottoman56
VAG-COM Discussion
Oct 8, 2015 05:59 AM
thewatcher101
Dec 28, 2005 03:07 AM
Raoul
Nov 5, 2002 12:52 PM
WickdS4GoByeBye
Aug 4, 2000 11:57 AM
