CD Unit and clock question
Old Feb 4, 2005 | 08:51 PM
audi100man's Avatar
New Member
Default CD Unit and clock question
I have a 1992 audi 100cs
1. the car came with a BOSE audio system. I want to install a Faceplate(cd player). Should i just take it to a professional or is it easy enough to install by myself.
2. THe clock is incorrect ever since i got into my accident. The **** that's supposed to change the time doesnt do anything. ANyone know how to fix it.
Old Feb 5, 2005 | 04:59 AM
djdc's Avatar
Default Re: CD Unit and clock question
Definatley go to a professional unless you have a whole day to do it. In order to change one componenet in a Bose system you have to change them all. So, if you install a faceplate, you'll have to run new wires (or figure out which old ones you can use), and put in all new speakers. Personally- either find a factory CD changer on Ebay- or try installing an aftermarket one. Good Luck.
Old Feb 5, 2005 | 06:47 AM
4N 4RING's Avatar
You have to bypass the door amps and the rear amp if you install new speakers.
Old Feb 7, 2005 | 08:58 PM
E-Town's Avatar
Default BOSE magic...
As I understand it the main issue with swapping out the BOSE system is the fact that the amplifiers for the speakers are external to the deck. Most stock, and non-competition aftermarket decks have the amplifiers built in.
The problem arises when connecting the amplified signal from the new deck to the BOSE speaker/amplifier setup. If you connect to the amps you will blow them, if you connect to the speakers the system will sound like crap because the speakers are matched to the amps.
Now if my knowledge of audio gear is correct, the easiest solution is to replace the deck with one that has front and rear preout connectors. These put out an un amplified (line level) signal which you should be able to run to the BOSE amplifiers without causing them any harm.
Now I won't guarantee that this will work properly but if you can wait a week or so I'm going to give it a test in my car and I'll let you know the deal then.
As for the clock...mine's been off since daylight savings, if you figure it out let me know.
RustyKelsea420
Nov 3, 2008 12:17 PM
~DonQPremiumTequila~
Audi Original "S" Cars
Feb 8, 2007 03:00 PM
dingofarmer
Jan 28, 2006 09:55 PM
Type44Q
Nov 16, 2002 11:45 AM
ctrain42
Jul 1, 2002 06:56 AM
