climate control module question.....
Old Dec 23, 2004 | 07:22 AM
ADAZZ's Avatar
Member
Default climate control module question.....
hi guys. long story short my audi repair shop replaced the vent actuator/servo motors in my 100csq which required removing the dash. anyway, once everything was put back together, the illumination of the left hand side display (temp)on the climate control module is now out. does anyone know if it is blown bulb or some "plug" that wasn't plugged in when they reinstalled everything? thanks in advance.
Old Dec 23, 2004 | 07:30 AM
Rick 601's Avatar
Junior Member
Default If everything else works it's probably a bulb. ...
On my 96 a6 there are 4 bulbs in the back- they screw in- you don't even HAVE to remove the cables to replace it. Also it could just be loose...
Old Dec 23, 2004 | 08:01 AM
ADAZZ's Avatar
Member
Default is it easy to replace? i don't have time to take it back to them
though i think should since i paid them a pretty penny to do the job...should be done right!
Old Dec 23, 2004 | 08:16 AM
Rick 601's Avatar
Junior Member
Let them know thast there is a problem and you will return at YOUR convenience
Q5Ind
Q5/SQ5 MKI (8R) Discussion
Aug 19, 2012 07:38 AM
big_anthoiny
Jun 2, 2004 11:09 AM
AEGA4
Jan 21, 2002 04:41 PM
Sterling
Dec 17, 2001 12:15 PM
dabrun
Dec 2, 2000 06:07 AM
