Does the gear selector lock in P when the key is removed?
Old Aug 24, 2006 | 09:17 AM
SoCal  Avanti's Avatar
Default Does the gear selector lock in P when the key is removed?
In my '96 it can be taken out of park and put into any gear with the key out. Also, when it's running, when you depress the brake pedal, there is a definite "click" that comes from inside the console near the shift ****. It's always been this way since I bought the car 3 years ago, but somehow I don't think that's the way it's supposed to be. I assume a pin or something has come undone in the shift mechanism?
So, another thing is how to get at the mechanism. You dont have to remove the whole center console do you?
Old Aug 24, 2006 | 09:30 AM
Fair Cape-Cape Town's Avatar
Junior Member
Default Re: Does the gear selector lock in P when the key is removed?
The shift should be locked in park when the key is removed. Likewise the key can't normally be removed if the shift is not in park.
You need access to the Bentley manual to make the adjustment correctly.
Old Aug 24, 2006 | 11:32 AM
DaveInSaltLake's Avatar
Default Click upon pressing the brake pedal
My 92 100 has an audible click at the shifter when I press the brake, and my shift lock seems to work as designed.
Old Aug 24, 2006 | 04:07 PM
Default Okay I figured it out
The click is the neutral safety switch, and the problem of not locking in P was the cable that pushes a plunger onto the plastic cog on the shifter that holds it in place while in park. It just happened that the cable can be adjusted in and out and mine was too far out to make contact on the the lever. And yes, I removed the center console to do it.
robbyfritzler
Audi allroad
May 25, 2016 10:31 AM
EuroVWGTi
10
Jun 27, 2008 02:21 PM
jjhurayt
Feb 29, 2004 03:27 PM
werstiii
Audi 100 / A6 (C4 Platform)
Mar 22, 2002 01:55 PM
misteraudi
Jan 28, 2002 10:17 PM
